10-11-2019 11:40 AM
nice!
10-14-2019 01:32 AM
Thanks !
10-14-2019 01:37 AM
I want to modify this switch such that when clicked it and dragged up it goes up and when clicked and dragged down it goes down. But here it goes up and down only in a sequence. Any idea how to do that?
10-14-2019 01:50 AM - edited 10-14-2019 01:51 AM
Hi Neha,
you asked that before - and you already got an answer before!
3 days later you need to ask the same question again?
10-14-2019 02:46 AM
Yeah, Actually I cannot use the slider. I need to use the same switch as uploaded in the file.
10-14-2019 03:10 AM
Hi Neha,
Why do you think you need to use a PictRing when it doesn't help you to solve your problem?
Have you read the comments on control customization - and have you read the LabVIEW help on that topic?
10-14-2019 03:16 AM
Yes, I have.
I need to use something like a switch which can be take 3 positions (middle, upper and lower). But something like that is not present in labview. I got this file but then it is not giving the outputs as expected. Can it be edited to give that output??
10-14-2019 03:23 AM
Hi Neha,
There is a slider or a dial, which can take 3 positions…
This "file" mainly consists of a PictRing. Do you know/understand how this works, especially as control?
Surely you can edit a PictRing…
And you can apply some more code in the VI to enforce the behaviour you want to show on the frontpanel…
10-14-2019 03:56 AM
Yeah, I have a little idea about the pictRing. Is there some other method to get a 3 position switch with the functionality mentioned above if not pictRing? And how can I implement the functionality needed by me in the pict Ring itself?
10-14-2019 04:04 AM
Hi Neha,
You can draw any image in a 2DPictureIndicator, depending on your user input. Or customize dials/sliders as needed.
Depending on the user input you can switch the PictRing to the corresponding picture. PictRings are even used to show small animations by switching images constantly…
