I need to reverse a byte
Hi All,
I know this is an old topic but maybe the results (execution speed) are interesting for others...
Reversing a byte by using Look Up table.
Additionally  enabling / disabling the debugging option influences the execution time heavily  when the method "bit shift operations" are used for byte reversing..
See below  LV7.1
Regards
Tomi
Message 11 of 12
(807 Views)
Tomi,
I agree, a lookup table is always the way to go, even for 16 bits, assuming that you need to convert more often than the size of the lookup table. 😉
Typically, you would encapsulate this in a subVI and place the lookup table in an uninitialized shift register. Use a case connected to a "first call?" primitive so the lookup calculation is done only once (Since the lookup table is folded into a constant by the compiler anyway, the calculation for the lookup table will happen even before you run the VI so most likely there won't even be a penalty at the first call :)).
For some related examples, have a look at the code for my tic tac toe program posted at the following link:
Here I use a similar method to e.g. calculate the number of bits set in a given U16 integer (see U16BitsSet.vi) or find the unique transform of a position (UniqueTransformCached.vi).
For an 8bit table, you could just calculate it once and then place it as a diagram constant. It will only increase the size of the VI by ~256bytes... peanuts! 😉 Still, I prefer explicit code for the table generation, because it is easier to tell if there is a mathematical error.
Message 12 of 12
(788 Views)
