I need to open/import a .bin file in to LabView
I would like to open a .bin file in LabView for DSP purposes.
(2,244 Views)
Hello Researcher,
Depending on what format the data in the .bin file is in, there are quite a few paths you can take. One method is posted here, which explains how to do it with data quadruples. If you are receiving unreadable data, say like a wav file, then here is some related information.
If possible, would you be able to post an example of the data you are reading and how you intend to present it in LabVIEW? This would help narrow down the possibilities
. Thanks!
Jeremy L.
Jeremy L.
(2,244 Views)
