I need to create an analog output that varies from 0-5Vdc, based on a value that varies from 1x10^-6 to 1x10^-3
OK, so here I am again.  I am almost done with this application.  I measure a helium concentration, which usually varies from approximately 1 x 10^-6 to as much as 1 x 10^-3.  I need to create an analog output that varies from 0 to 5 Vdc, based on this concentration.  The problem is that I don't know the exact minimum or maximum that I might ever read.  So I have two questions.  One, how do I determine a value that I should use for min/max, to ensure the best resolution possible?  Second, how do I implement the scaling (0 volts = 1 x 10^-6 and 5 volts = 1 x 10^-3).  I know this is not a complex thing, but I'm burned out after 18 days' straight programming and debugging this application.  Any help is ALWAYS greatly appreciated.
(2,933 Views)
It depends on what you want to DO with the signal. If you want to display the value to a user then a log scale would be a good idea.
You need to realize that if you convert to linear values you will have much poorer resolution at the low end of the scale.
(2,932 Views)
I need to send the voltage to another system, which will in turn be scaled to display for an operator the helium concentration (in ppm) based on the voltage received (0-5V).  would it be possible to split into mantissa and exponent?  If so, how do I do the scaling?
(2,930 Views)
If I understand correctly you want a 1 ppm to 1000 ppm scale that corresponds to your 1x10^-6 to 1x10^-3 values. If X is the original value, Y is the ppm value, and V is the voltage, then Y = 10^6*X (ppm) and V = 5*Y/1000 (volts). Or V = 5000*X.
If you want to allow some overrange, you could set 0.5 volts to be 1 ppm and 4.5 volts = 1000 ppm. Change the formulas above to adapt.
Lynn
(2,926 Views)
feeling sheepishly dumb right now...I came up with the same thing 5 minutes ago. Sometimes I can't see the forest for the treesSmiley Tongue   thanks for the help.
(2,923 Views)
I think your "...burned out after 18 days' straight..." comment in the original post explains it all. Sometimes you just have to take a deep breath and get a little nudge in a new direction. Glad you figured it out.
lynn
(2,919 Views)
