05-28-2008 04:42 AM
05-28-2008 05:10 AM
05-28-2008 06:03 AM
Hi tst,
I did nt find any details for programming in Labview. In Manual , the commands are mentioned. Can u send me the labview code to read the data from motor or write data to Motor. r u using this motor. In Manual, it explains about the IMS Terminal,but not using Labview.
If u have any notes or material,Send it to ganeshbabuks@yahoo.co.in
Regards
Ganesh Babu
05-28-2008 06:45 AM
05-28-2008 11:00 PM
05-29-2008 01:38 AM
I don't remember having specific problems with communicating with it. If you can do it in Hyperterminal, you should be able to use the same settings to do it in LabVIEW. Just make sure you use the exact same settings and that you append a CRLF.
If you tried that and it still didn't help, you should upload your code. We might be able to see something in it.
05-29-2008 01:42 AM
05-29-2008 05:02 PM
05-29-2008 09:20 PM
Simple question.
Are you sure you have closed the serial port in Hyperterminal before trying to run the code in LabVIEW? Or that the Motor software is closed out and shutdown? The error sounds like the kind you get if a different application has the Com port open.
05-29-2008 11:42 PM
Hi All,
I thank everybody for ur Valuable comments. i solved the problem. I still get errors but i can able to control the motor.
Ganesh Babu
