I need help to convert a (HEX 1.15) to a decimal file,and then plot it with LabVIEW.
(2,480 Views)
The best way is to use the HEX to decimal coversion VI in the string pallette. Then, write this decimal directly to your chart. If you are doing it a point at a time put it into a while loop.
Doug
(2,480 Views)
