‎03-25-2008 09:36 AM
‎03-25-2008 10:32 AM
Hi M.Shair,
did you install the VISA runtime engine, too??
Mike
‎03-25-2008 10:52 AM
Hi Mike,
No I didn't install the VISA runtime engine, but untill now I'm deploying my executables without the visa functions yet.
so i think that won't be the problem, Maybe.....
M.Shair
‎03-26-2008 10:52 AM
‎03-26-2008 12:33 PM
‎03-26-2008 12:35 PM
‎03-26-2008 01:21 PM
‎03-27-2008 03:39 AM
Hi Mehak,
thanx for that little note, becuse now i can run it on another computer.
but still one problem I'm facing which is, I 've already included in my software to deploy my library Programmatically and i 've tested my sotware on a computer that have labview installed and it's worked
but when i run it on a computer that doesn't have labview it gives error messege that the shared library can't be located and deployed.
one more thing, I'm using Data Base Connectivity toolkit in my software so should I include anymore files to installer.
‎03-28-2008 03:04 PM
‎03-28-2008 05:12 PM
about the data base i've checked these links already before and i've done what is mentioned in them but actually I couldn't check it working or not because like I've told before there's a problem with the shared variables because it gives an error that they can't be deployed.
so I was wondering if there's something I;ve to include or do according shared variables to run on an executable
by the way I've tested my sotware on a computer that has labview installed and it worked and I 've included to my installer the NI variable manager & NI variable engine
I'm waiting for your and hoping to find the answer too
thanx
