I need a solution for a lab view apllication and installer problem
I ,ve already deployed an application and an installer, when i run the executable and the installer on my laptop it run well,
but when i run them on a computer that does'nt have a labview it gives me a messege says that i need to install the labview run time engine 8.5
actually i 've included the run time engine to the installer and i 've installed the run time engine from labview 8.5 cd,
but it still give me the same messege.
information you might need:
I'm using in my project the following:
-network shared variable
-data base connectivity functions
-report generation functions
-visa functions
so if any one can help me with this up?????????
Mahmoud Alshair
Intelligent Systems Integrator ( ISI )
System Developer
Message 1 of 13
(3,119 Views)
Hi M.Shair,
did you install the VISA runtime engine, too??
Mike
Message 2 of 13
(3,106 Views)
Hi Mike,
No I didn't install the VISA runtime engine, but untill now I'm deploying my executables without the visa functions yet.
so i think that won't be the problem, Maybe.....
M.Shair
Mahmoud Alshair
System Developer
Message 3 of 13
(3,102 Views)
Would it be possible for you to provide the screenshots of your build specification for the installer and the executables?
Mehak D.
Message 4 of 13
(3,078 Views)
Dear Mahik
I 'll post some snapshots of my project here so you can checke it out.
just let me tell you that when I run my app. & my installer on a computer that has a lab view and DSC it works well,
but when I run it on computer that doesn't have a labview it gives that error messege.
i'm hopefullt waiting for your reply with some solution
thanx
Mahmoud Alshair
System Developer
Message 5 of 13
(3,063 Views)
Here are more snapshots for my project also
Mahmoud Alshair
System Developer
Message 6 of 13
(3,062 Views)
All applications built using the LabVIEW DSC module require the LabVIEW DSC runtime engine installed in addition to the LabVIEW runtime engine. The DSC runtime engine has to be purchased separately. Do you have the DSC Runtime Engine installed on this computer?
Mehak D.
Message 7 of 13
(3,055 Views)
Hi Mehak,
thanx for that little note, becuse now i can run it on another computer.
but still one problem I'm facing which is, I 've already included in my software to deploy my library Programmatically and i 've tested my sotware on a computer that have labview installed and it's worked
but when i run it on a computer that doesn't have labview it gives error messege that the shared library can't be located and deployed.
one more thing, I'm using Data Base Connectivity toolkit in my software so should I include anymore files to installer.
Mahmoud Alshair
System Developer
Message 8 of 13
(3,032 Views)
If you are using the database connectivity toolkit you need to follow a few steps in order to run the application executable on your target PC. These steps can be found at the following link:
There is another link that provides more specification on following these steps on executables built using 8.0 and later:
Please let me know if this helps in resolving the problem!
Mehak D.
Message 9 of 13
(2,994 Views)
about the data base i've checked these links already before and i've done what is mentioned in them but actually I couldn't check it working or not because like I've told before there's a problem with the shared variables because it gives an error that they can't be deployed.
so I was wondering if there's something I;ve to include or do according shared variables to run on an executable
by the way I've tested my sotware on a computer that has labview installed and it worked and I 've included to my installer the NI variable manager & NI variable engine
I'm waiting for your and hoping to find the answer too
thanx
Mahmoud Alshair
System Developer
Message 10 of 13
(2,986 Views)
