I need a ROI of FIXED Size
@MarcoMauri wrote:
Hi!
Try this one.
I'm capturing the mouse click and creating on the fly a rectangular ROI of a given size.
Marco
p.s. change the X and Y size of a ROI to a value different from 0... I forgot to update  the default value.
Hi Marco,
Thanks a lot. It is working very well. I able to code with help of your reference vi attached in your post.
NOw I am facing another problem -
"Error -1074396154 occurred at IMAQ WritePNGFile
Possible reason(s):
IMAQ Vision:  The image is not large enough for the operation."
Even after cropping a 100X100 ROI I am getting this message from a IMAQ Write File 2 vi. It has been used to save the cropped ROI.
I am trying hard to fix it.
I shall be thankful if anyone can pu some light on it.
Thanks.
Message 11 of 19
(1,951 Views)
Hi sukhiray, please attach your code which is generating the error. I tried to save mine for 2012, let's see if it works:
Message 12 of 19
(1,936 Views)
Thanks gregoryj for your support. These are openable.
Now the previous problem has been solved. Presently I am getting trouble in saving the cropped ROI. See the attached code, The last vi to save image is returning error. I have attached the code and error snapshot.
I shall be thankful if you can help me to findout the problems or mistake in my codes.
Thanks again for your active participation.
Message 13 of 19
(1,916 Views)
I use another method with more flexibility test this vi too
Message 14 of 19
(1,903 Views)
Thanks Hatef.
It is also working good but it is adding fill color which is not required.
Till thank you very much for your support.
Message 15 of 19
(1,862 Views)
there is the control in vi that you can select three method for roi
frame
highlight
and fill
chnge fill to frame for not filling
Message 16 of 19
(1,848 Views)
HI all, Thanks for your support.
My code is runnign well with floating ROI of user defined size.
Now I am getting an odd problem with IMAQ readfile vi. Sometimes it is working really good but next day it is showing error like -
Error -1074395995 occurred at IMAQ ReadFile
Possible reason(s):           IMAQ Vision:  File not found.
I am really confused. Can anyone help me to understand this?
Message 17 of 19
(1,822 Views)
vi please
Message 18 of 19
(1,809 Views)
VI can't be uploaded as it is part of a big program and extracting that part will includes a huge hazzard.
I have solved this problem by designing my own VI for the same.
Message 19 of 19
(1,784 Views)
