I need a ROI of FIXED Size
      I am working on image processing. In my present work I need to crop ROIs from images but the size of ROI should be same for all. So I have to fixed the dimension of ROI through block diagram coding so that all the cropped ROI finally will be of same size.
I able to find a way to create a ROI of a given size, movable on the image using Convert Rectangle to ROI vi. But the rectangle is till resizable. Is there anyway to fixed the size?
Please help me out.
Message 1 of 19
(6,339 Views)
You can check ROI size after it has been moved (check image event mouse up) and discard size changes.
Or
You can track position of user specified ROI-point and overlay rectangle on image to show user the resulting processing ROI. There is a little confusion: ROI on the image display is only user interface and ROI as region of interest for processing.
Message 2 of 19
(6,311 Views)
Or
Thanks for your support and response.
Please see the attached image file. How to reset the rectangle size if anyway altered by user?
I am also not getting any way to find the ROI-point, can you please help me?
Message 3 of 19
(6,275 Views)
Please attach the VI, not a picture.
If the size is really critical, I would make the user set the width, height, and left and top offset using numeric controls.
Message 4 of 19
(6,264 Views)
pleasesee the attachment... my requirement is keeping the ROI size fixed, not the image size is my concern.
Message 5 of 19
(6,256 Views)
You can do something like this, run ROIsample.vi. You do have to have an ROI drawn already, but this was something I was specifically asked for by one of my users.
Message 6 of 19
(6,246 Views)
You could allow users to define only point ROI and draw the fixed size rectangle as an overlay.
It will up to you to translate the point to a rectanglurar ROI whenever needed.
Marco
Message 7 of 19
(6,239 Views)
Thanks gregoryj. As I am using labview 2012 can't open your files. Can you please save them in compatible mode and re-share?
Thanks for your support.
Message 8 of 19
(6,217 Views)
Marco
Thanks Marco, but I can't extract mouse information fron that vi I am using. Can you help in that?
Message 9 of 19
(6,214 Views)
Hi!
Try this one.
I'm capturing the mouse click and creating on the fly a rectangular ROI of a given size.
Marco
p.s. change the X and Y size of a ROI to a value different from 0... I forgot to update  the default value.
Message 10 of 19
(6,190 Views)
