I'm using the simulation interface toolkit V2.0 but it works only the first time after the installation. When I restart again my computer it doesn't work any more. Why??????????
I'm using labview 7 on a pc with windows XP. We are trying to use the new simulation interface toolkit V2.0. When I install it and soon after I use it everything works good (except that the SIT connection manager is run two times in Matlab but this doesn't affect thefunction of the system). When I shut down my computer and I restart again the SIT doesn't work anymore (I can't even select the simulink file)unless I install the toolkit again. I've tried to patch it with the V2.0.1 but the problem still remains. Does anybody has the same problem? or anybody knows how to solve it?
(2,886 Views)
"barbara" wrote in message
news:506500000008000000FAC20000-1077587809000@exchange.ni.com...
---snip
I am not familiar with the different software that you mentioned but as a
first step I would check compatibility which is done as below:
Get original operating system CD that was used to install Windows XP on the
machine in your post. When Windows XP is inserted into CD ROM drive it
normally will ask you to conduct compatibility check for the current
installation. See what it says.
HTH
Mohan Pawar
----snip
(2,886 Views)
I am interrested if have found a solution to you answer. I have a similar problem, where matlab tells me that the server is running on xxx port but checking that with netstat -na from a command prompt the xxx port is not open. My main issue is that I can't figure out why the server doesn't open the port? Anyhting you might have leraned would be helpful
(2,886 Views)
