I'm trying to connect a subVI with my VI, they both share common variables and the subVI is not reading one of the variables from the main VI...
I can't figure out why the subVI will not read this one particular variable from the main VI. How can I figure out how to make sure these two VI's are communicating properly?
(2,551 Views)
Your question is a bit vague.
In order to make sure you are passing data correctly, you must have inputs to the subVI that are satisfied by data from the main (calling) VI.
If this doesn't help. Try posting your code or offering a more detailed explanation.
(2,551 Views)
Yes, please post example.
We could probably give you an answer rather quickly if you did.
Ben
(2,551 Views)
