09-13-2016 10:29 AM
First off, i have never used LabVIEW a day in my life. i have to use a mydaq to run a relay that controls a heater. I have create a VI that will countdown any input amount from 1 hour up to 12 hours that comes on when the time is selceted and shuts off when the timer ends. Any help will be greatly accepted....
09-13-2016 11:33 AM - edited 09-13-2016 11:36 AM
Start with below links to learn about LabVIEW programming and post VI/snippet which you tried and where you are stuck exactly instead of asking for full solution.
LabVIEW Graphical Programming Course
09-13-2016 02:38 PM
Presumably someone in your Institution qualifies as a LabVIEW Guru. Maybe they teach LabVIEW, maybe they're the "go-to person" when a student in Senior Design realizes "Oh, no, I need to learn LabVIEW quick, who should I see?". Ask your fellow students and faculty, and go "apprentice" yourself for a week (means try to arrange to spend at least an hour a day with them).
LabVIEW is pretty easy to learn the "basics", especially if you have some guidance (the Tutorials aren't bad). To get good at it, a mentor ("guru") can be very helpful, especially in teaching you about LabVIEW "Style", and some important "Do"s and "Don't"s.
09-13-2016 11:38 PM
09-13-2016 11:56 PM
Getting any example from your friends in the school would be great help
09-14-2016 02:21 AM
this could be also a good start for you..
Rajamodol
