I loaded labview 7.1 and NI-daq 7.3 and am having issues
I loaded labview 7.1 and NI-daq 7.3 and when I try to access one of my tasks created in max I am getting an error. I can test the cannels in max and they work fine. And I can create a task constant in the block diagram and choose from my tasks, but when I try to run it I get an error on the first vi it goes into. The error text I recieve is this --- Property Node DAQmx Timing (arg 1) in DAQmx Timing (Sample Clock).vi->test.vi Task Name: MyVoltageTask. I also tried uninstalling labview and ni-daq and that did not help.
(2,745 Views)
Hi Craig,
Could you give me the error number assosciated with the error message?
The error could be caused for several reasongs, the error number will greatly help in tracking down the cause. Most likely, the solution will not involve a reinstallation of LabVIEW or DAQ. Instead you may have one of the inputs to the VI wired improperly.
Sal
(2,736 Views)
