I like to write a program in LabVIEW that uses the Enhanced Parallel Port in Windows NT
to drive a motor. I already have a program for Labview to use the Standard Parallel Port, but this isn' t working in EPP mode. Does anyone has any suggestions, maybe where I can get drivers etc. or programs to control the EPP in LabVIEW under Windows NT?
(2,215 Views)
to drive a motor. I already have a program for Labview to use the Standard Parallel Port, but this isn' t working in EPP mode. Does anyone has any suggestions, maybe where I can get drivers etc. or programs to control the EPP in LabVIEW under Windows NT?If your don't really need EPP you can probably change the bios settings for the parallel port to "Standard".
-Jim
(2,215 Views)
