I inherited a huge program, and it won't stop growing.
Literally, it grows on its own. Everytime I place a new control, remove something, move something, or do anything a bunch of the terminal in the block diagram shift to the right. And since every structure is set to auto grow, they do just that. I don't know why this is happening, I've never see this on any program before. If I had the time to completely overhaul the program I would, but that is not an option. Does anyone know if there is a specific bug or option that could be causing this?
Message 1 of 8
(873 Views)
Hi pndavkota,
So you know "autogrow" is enabled, but you don't know why your block diagram grows upon placing more items inside such structures?
Well, I recommend to refactor such "huge" block diagrams. Really!
An enabled options is not a "bug"...
Disable that option for all structures!
Message 2 of 8
(862 Views)
@GerdW wrote:
Hi pndavkota,
Some developers love the auto-grow feature and are very proficient at using it.  I am not one of those.
Bill
CLD
(Mid-Level minion.)
Message 3 of 8
(830 Views)
What version of LabVIEW are you using?  An odd thing was observed and solved here.
Jim
Message 4 of 8
(829 Views)
It's also been known for a long time that very large block diagrams will cause all kinds of weird issues (I don't remember the exact size that things to haywire).  So the solution is to refactor and use subVIs.
GCentral
Message 5 of 8
(818 Views)
@billko wrote:
@GerdW wrote:
Hi pndavkota,
I'm with you.  Here are some other things I don't like:
  • FP Terminals as icons
  • Auto-insert Feedback Node
  • Automatic wire routing
  • Lock automatic tool selection (I absolutely hate this one)
  • Drag Autowire (turn this off with "DragAutoWire="False" in labview.ini)
Message 6 of 8
(802 Views)
The coordinates are I16 and anything can happen if you start wrapping.
Message 7 of 8
(765 Views)
There is a tool called "Nattify" that you can use to turn off all auto-grow in all structures at once in a VI.
It does a number of other things too that many (but definitely not all) LabVIEW developers like to have altered, so check what else it does before you do it and it changes other things you weren't expecting.
Message 8 of 8
(735 Views)
