04-16-2022 04:33 PM
Dear all, I have a setup that works with a Sensirion sht30 sensor and want to get humidity and temperature
I use an Arduino board and Linx library that work properly.
my problem is how to set commands for "i2c read" and "i2c write" blocks to get humidity and temp.
I had made a file for monitoring the sht20 sensor and it was ok, but I couldn't change it for sht30. datasheet of the sensor is attached.
I would be so appreciated if anyone can help. thanks
04-18-2022 03:08 PM
What code did you write for the SHT20?
And why doesn't it work for the SHT30?
04-20-2022 03:44 PM
hi, thanks for your response.
files related to sht20 and sht30 were attached.(ver:2020)
06-30-2022 03:19 PM
Hi, were you able to solve your issue?
07-28-2022 09:21 AM
Home--colinzhang.net: My Blog
