I have problem with NiDaq69.exe and LV5Fra.exe drivers for NT operating system that I've download from ni web site.
I am using PCI-6110E data acquisition board and Labview 5.0. Then I've installed those drivers correctly. So in Labview I didn't find all the VI data acquisition.
How can I do to communicate and acquire data from PCI-6110E data acquisition board using LABVIEW 5.0 ?
(2,555 Views)
Hello;
When you install NI-DAQ you have an option to select the support files for the programming language used. On that point, you need to choose the support files for Labview 5.0. Otherwise, you won't see both the DAQ VIs and the Data Acquisition examples for Labview.
Hope this helps.
Filipe
(2,555 Views)
