04-23-2002 09:59 AM
04-23-2002 11:05 AM
12-29-2004 10:03 PM
07-14-2005 10:53 PM
Hi Preston,
I believe you have developed some VIs for CNC G-codes. I would be really thankful to you if you can share it with me. Thanks.
Giridhar Rajan
Cruiser Controls
Mumbai, India
07-17-2005 11:00 PM
Hi Mr.Preston,
This is a request from me that if you have any G-code related VIs then please share them with me. I will be really greatful to you for those. I'm involved in a G-code and M-code based LabVIEW project these days and I badly in search of a few examples to get some idea abt. it and proceed further. Thank You.
Giridhar Rajan,
Automation Engineer
Cruiser Controls
Mumbai, India
03-03-2011 10:35 AM
Good morning, I am interested in Part 1 that you mentioned "There Are G code translation VIs That take commands from the CNC and say AutoCad command with the NI 7344 to move the three axis CNC machine tool. I can Provide These for evaluation if you like. "I wonder how I can do this because I'm working on a project in which I want to control a CNC milling machine with labview, Thw CNC milling machine is not working and I want to control the stepper motors with Labview. The part that interests me at the moment is that you mentioned the traslation of G codes, I want to know Which VI or module is necessary, . I would like if I could help.
03-03-2011 03:08 PM - edited 03-03-2011 03:09 PM
Of the previous posters, only Preston Johnson has been on the forums in the last few years, some not having been on in the over 5 years since the last post before yours. It is good to do a search on a topic, but then if the most recent discussion was not recent, start an new thread.
03-04-2011 11:13 AM
The NI Motion Assistant has now incorporated similar functions:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/11091
The NI Motion Assistant offers the ability to import motion profiles created in CAD or drafting packages using the widely accepted DXF file format. Using this feature with the NI patent-pending smart-contouring algorithm, you can implement precise motion profiles for cutting or scribing applications.
So if you can convert your CNC files, or create a DXF file from the tool that created the CNC files, then Motion Assistant will perform the needed functions.
03-07-2011 10:36 AM
Thanks,your answer helped me a lot, I will contact my supplier of National Instruments in my city, . Thank you very much.
Meybe in the future i have other some cuestions. Thanks
04-14-2014 03:19 PM
hello, can you help me?, i need a g-code and m-code interpreter, using labview. or an example like that.
My project its to create a cnc mill control using labview, with NI PCI-7334 and the HUMI 7774.
I have been tested my 7334 and the HUMI 7774 with my stepper motor and everythings its ok. the 3 axis move. But i need an little example of a G code interpreter.
I apreciate your help, thanks a lot.
