09-30-2008 04:19 PM
09-30-2008 04:32 PM
09-30-2008 05:36 PM
Can you post your VI, or at least a quick program that displays your problem?
I don't see how that could happen.
Have you tried physically dragging the unbundle function so it displays 12 channels instead of 9?
09-30-2008 09:08 PM
flippo wrote:
Re: I have a 12 channel waveform going into a cluster, why does only 9 channels out
Define "going into". 😮
Clusters are fixed size. If you want a cluster with 12 channels, you need to define it that way.
If you have an array of waveforms and are using "array to cluster" to convert, you need to right-click on the "array to cluster" primitive and specify the cluster size. The default is 9, so that seems to be your problem. Change it to 12.
