I got error 8: vi resource not found After copy the project to another location
I copied the project folder in C: to 😧
I opened a .vi file in 😧 then closed LabView.
I try to open the same .vi file in C:   I got :"LabVIEW Load Error Code 8 -   Could not find VI resource".
I checked all the files in C:  no file have been modified.
I'm using LabView 5.1 with Windows NT.
Any help would be greatly appreciated.
(2,644 Views)
Suesong,
This KB seems to suggest that the erro you are getting is a result of the Vi in question being compiled in a newer version of LabVIEW:
http://forums.ni.com/ni/board/post?board.id=170&message.reply_to_id=240257
Did you open it up in a newer versions and save it?
Xaq
(2,626 Views)
