I discovered another "nugget"
Perhaps some of you already know this but I just stumbled on it.
When you are filling in text for a lable of a control or indicator or plain text documentation lable, you can terminate it with the Enter key of the numeric keypad.
Previously I would change from the text tool with the Tab button then click somewhere outside the lable.
(6,113 Views)
Yup, I remember learning that one when I took LabVIEW Basics a little over 7 years ago...I remember thinking, "LabVIEW is the only application I can think of where the Enter key on the numeric keypad and the Enter key on the standard part of the keyboard can do different things."  🙂
-D
(6,102 Views)
I remember thinking, "LabVIEW is the only application I can think of where the Enter key on the numeric keypad and the Enter key on the standard part of the keyboard can do different things."  :)
-D
Which can be good or bad -- bad, for instance, when using the MS Spreadsheet ActiveX Control:  can't use either keys to enter data in a cell and "apply."   I wish they both behaved the same.
-Khalid
(6,090 Views)
Hi Khalid,
If you want both "Enter" key to behave equally, you can set this up in "Options" >> Front Panel" and tick the first box "End text entry with enter key" afterwoards, add line in a text use "ctrl+enter" 😉
I think now the nugget if fully cooked Smiley Very Happy
Epictetus
Antoine Chalons
(6,088 Views)
Thanks for the reply, Titou.
However, the MS Spreadhseet ActiveX control is a different kind of beast...  err, nugget  Smiley Very Happy
With the option 'End text entry with Enter key' unchecked (default), the main Enter key "applies" the value to the cell.  And the Num-pad Enter key does not.
And with the option  'End text entry with Enter key' checked, neither key apply the value!
I guess we should take this discussion elsewhere... don't want to leave a bad taste on this thread.
-Khalid
Message Edited by Khalid on 03-28-2006 01:45 PM
(6,038 Views)
