I'd like to read all channels at once of one AMUX64T (with MIO-16-E4). Does anyone have an example programm for LabView?
It always says I have to use a 0:15 string, but I don't know how to do that. Does anyone have an Example VI on how to aquire all 64 Channels at once?
(2,218 Views)
Hello;
The same Analog Input example VIs you use with any DAQ board, you can use to address the AMUX-64T as well. The only change you will need to do when typing the channel numbers in can be found at the manual named: "Labview Data Acquisition Basics Manual", chapter 5, section named "Things you should know about Analog Input". That manual can be found at our web site. That section states the correct syntax you should type in to address the AMUX channels.
Hope this helps.
Filipe
(2,218 Views)
