Stephan wrote:
> I am trying to uninstall labVIEW 6.0.2 so that I can use my license
> else where. When trying to remove the program from the control panel
> 'add/remove programs' applet the exact error I get is;
> Error applying transforms. Verify that the specified paths are valid.
> I also get this error when trying to install the prgram over top of my
> initial install. Is there specific paths in the registry I should
> examine or other approaches to uninstalling LabVIEW? Any help is
> appreciated.
Go to the Knowledge Base
http://digital.ni.com/public.nsf/MainPage?OpenForm&node=133020_US &
search for "applying transforms".
Use the double quotes to make sure that you search for the exact string.
You'll get 2 hits, one of which will solve
your issue.
Mark
