I can't select "Database variant to data" in the functions palette
I use Labview 8.2.1, and I have a problem when I try to select Connectivity->Database->"Database variant to data". Nothing happen. All others icon that I click work. Is this bug already happen to someone? How can I solve this problem?
Message 1 of 12
(5,005 Views)
Did you try repairing or uninstalling and reinstalling the DB toolkit?
___________________
Try to take over the world!
Message 2 of 12
(5,001 Views)
me too I have the same problem. thinks for your help.
Message Edité par tlyazid le 06-14-2007 01:59 PM
Message 3 of 12
(4,992 Views)
I have the same problem with 8.2.1.  It isn't possible to select the Database Variant to data icon on the pallette.  I tried to locate it in <vi.lib>\addons\database but it almost looks like all the bits are there that is supposed to make up the vi but that it hasn't been put together. . .
Anyway I hope one of the NI engineers picks up this thread and gives us a solution.
Message 4 of 12
(4,967 Views)
I am also able to reproduce this!  I will file a Corrective Action Request and let you know if there is a workaround.
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
Message 5 of 12
(4,948 Views)
Below is a KB that addresses this issue and solves the problem.  I tried this out on my machine and now I can drop down a Database Variant to Data.vi.
http://digital.ni.com/public.nsf/allkb/CEE92D0FB321402586257193005DF125?OpenDocument
Daniel Eaton
Systems Engineering
Message 6 of 12
(4,941 Views)
Thanks I have tried it and it works.
Message 7 of 12
(4,916 Views)
This did not work for me in 8.5. The "_DB Variant To Data" folder is not even in the 8.5...addons\database folder. Anyone know what's up?
Message 8 of 12
(4,669 Views)
Have you tried reinstalling the toolkit after you installed LabVIEW 8.5? Toolkits will install to the latest version of LabVIEW installed on your computer. Are you able to follow the instructions in the KnowledgeBase article mentioned above?
Amanda Howard
Americas Services and Support Recruiting Manager
Message 9 of 12
(4,652 Views)
Installation. This is a sore spot. In order to install my toolkits to 8.5 with 8.2 still installed the toolkits have to be unistalled from 8.2 first. (hint - copy your entire 8.2 -current version- folder before you uninstall the toolkits to copy back when 8.5 toolkits installed). That is a long story. Yes I have it installed and everything works except this variant to data icon. I tried to copy the dir.mnu as mentioned in the knowledgebase
http://digital.ni.com/public.nsf/allkb/CEE92D0FB321402586257193005DF125?. Seemed this made the pallette worse - probably wrong version of dir.mnu. The folder under addons\database - "_DB Variant To Data" was missing from my 8.5 install. Copied it over from 8.2 and it still does not work.
Message 10 of 12
(4,630 Views)
