I can't select my COM port
Hi all,
I can't select my com port on linx firmware wizard beacuse of that I can't use my arduino mega2560 with LabView 2013(64 bit) if someone can help me, I will be pleased with help
thankyou
Message 1 of 9
(6,626 Views)
So, on which com port is your device connected?
Message 2 of 9
(6,597 Views)
com 1 is the slot I used but I can't find on Labview at the sametime on arduine I already can select the port
Message 3 of 9
(6,572 Views)
Hi, Check in NI MAX. It must detect over there in Devices and interfaces
Venugopal
Message 4 of 9
(6,549 Views)
I couldn't find, can you explain exactly way step by step ?
thankyou 🙂
Message 5 of 9
(6,514 Views)
Have you already installed the NI VISA driver from the link below?
https://www.labviewmakerhub.com/doku.php?id=learn:tutorials:libraries:linx:getting_started
Andrew B.
Application Engineer
National Instruments.
http://www.ni.com/support
Message 6 of 9
(6,494 Views)
Hi, You need to install device drivers you can find them in NI site
Venugopal
Message 7 of 9
(6,458 Views)
Accepted by Vidocq
This makes me think you are running Arduino IDE at the same time as LabVIEW, and the hardware might be locked by the software.  If LabVIEW is the only thing running, does it see your COM port?  Did you try reinstalling or repairing NI-VISA?
Message 8 of 9
(6,442 Views)
Accepted by Vidocq
Thankyou so much guys I fixed my problem with visa like you said you guys the best
Message 9 of 9
(6,426 Views)
