Hello;
It's looking like you inserted channel 0 at MAX test panel. If that is the case, you will most likely see noise only, since all channels of the SCXI module are multiplexed to channel 0 of the DAQ board.
The two possible ways to test an SCXI channel, is either by creating a Virtual Channel and then insert that channel in the Test Panel channel field; or, to insert the string ob0! sc1! md1! 0 in the Test Panel channel field. This string will address the SCXI channel 0 of module 1.
Hope this helps.
Filipe
