I have HP IPAQ PocketPC with Windows Mobile 2005, CF-6004 device, PDA 8.0.1 module and I installed DAQmx Base 2.0 on PocketPC. I followed instructions in documentation I get with DAQmx Base 2.0 and PocketPC is correctly conncted to PC. But I can not see CF-6004 in MAX?!? I found out somewhere that DAQmx Base support CF-6004 on Pocket PC 2003 OS but I did not found that information for Windows Mobile 2005 OS!
Devices that use the NI-DAQmx Base driver will not appear with Measurement & Automation Explorer (MAX). Instead, you should use the NI-DAQmx Base Configuration Utility found within LabVIEW under Tools > NI-DAQmx Base Configuration Utility.
Follow the instructions in the following Knowledgebase for loading the correct task list for use with the DAQmx Base shipping examples:
Also, with the new DAQmx Base 2.1, you can now use the CF-6004 Compact Flash Device with the LabVIEW 8.20 PDA Module to target Windows Mobile 5.0 devices.
I hope this helps,
Travis G. Applicaitons Engineering National Instruments www.ni.com/support
