02-05-2008 05:18 PM
02-06-2008 05:28 PM
02-07-2008 08:05 AM
02-08-2008 04:24 PM
07-28-2009 11:07 AM
Hi!
I am facing the same problem. I cannot get the VBtablet.dll to work properly. I register for events, but none are posted. It has been a long time since this question has been posted, so I am wondering if anybody found any anwsers on how to make the VBtablet.dll to work?
Thank you
Jernej Perhavc
07-29-2009 05:39 PM
Please look at the LAVA forums as Devin had suggested.
Ipshita C.
07-29-2009 08:11 PM
07-30-2009 01:43 AM
cueball wrote:I am able to see that events are generated from the dll, but somewhere between the ActiveX object and LabVIEW it is disconnected. Is it possible that LabVIEW is excepting these events and not allowing then into the code. The path as I see it isdll -> WinAPI -> ActiveX -> LabVIEWOne thing this dll requires is a windows handle and I am wondering if LabVIEW itself is reads the events directly instead of ignoring them. The reason I bring it up is that the tablet works like a mouse and I am wondering if it is absorbing these commands directly and not allowing them to be passed through the ActiveX object. Like thisdll-> WinAPI -> LabVIEWtherefore the event is never generated. That is why I wish I could speak with someone at NI that could explain that process better, but it seems like there is no one at NI who knows any high level issues.
First this are not high level issues but lowest low level issues. Some of it certainly is more Windows related than LabVIEW so support from MS, as unlikely it is to get that, would be at its place. NI people are not there nor can't really help you debug your VB issues.
Second you say it is a tablet and works like a mouse, then I'm wondering if Windows is not simply claiming it as a Human Interface Device itself and not really letting you control it yourself in your VB control.
Rolf Kalbermatter
