I can not find analog Input module
Labview 2014:I have installed NI-DAQmx base 15.0,but I can not find analog input module.does somebody know how to install analog input in Labview 2014.
(3,423 Views)
Accepted by alenter
  1. What kind of NI hardware do you have? Is it visible in MAX (Measurement & Automation Explorer)?
  2. Do you have a specific reason you installed the DAQmx Base pack, and not the full? Actually I do not know what are the limitations of the base package, but I always install and use the "normal" DAQmx driver.
(3,406 Views)
