I can not create an Installer, After install the Vision Builder Demo and then uninstall it. I can not create a Labview installer anymore, it asks me for a Vision Builder Installer, even if My Labview program does not have nothing to do with it...
I can not create an Installer on LabView, After install the Vision Builder Demo and then uninstall it. I can not create a Labview installer anymore, it asks me for a Vision Builder Installer, even if My Labview program does not have nothing to do with it...
(3,163 Views)
Accepted by topic author shada
 Hi Shada this can happen if you are including additional installers to your installer for example DAQmx. When you are doing this the installer has to include other files like MAX (Measuremente and Automation Explorer). Probably when you installed Vision Builder it updated MAX, so when your installer is trying to Include MAX, its asking for the source where it was installed in your computer in this case Vision Builder.
 Here you can cache the information so its not asked again, or you can download a newer version fo DAQmx, so it will update MAX and change de dependecy.
 You can find more details about this issue in this KB:
KnowledgeBase 3S88PJMY: Why Do I Get A "Missing Distribution" Error When Trying to Build an Installe...
And for keeping a copy here is more info:
 How Do I Stop the Missing Distribution Notification Each Time I Build An Installer?
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(3,149 Views)
