I built an application from application builder and tried to run it on another pc but it sadi runtime engine was not correct version I downloaded it from my application builder cd?
You must use the same runtime engine you used in development mode, so if you have upgraded to LV 6.0.2 you should upgrade the runtime engine too.I think there's some kind of problem with that, so search developer zone, i know the sollution was given not too long ago in this forum.
Good luck
(2,825 Views)
just check the installer option inside the application builder. Then the
runtime engine will automatical be installed.
Henrik
Joey Wood schrieb in im Newsbeitrag:
50650000000800000083260000-993342863000@exchange.ni.com...
> How do I get application builder to work on separate PC?
(2,825 Views)
