I am using an NI Data Acquisition board (PCI-6023E) with LabView taking inputs from temperature sensors (+5v VCC and 5V Vo) and airflow sensors (+12V VCC and 5V Vo). Can I mesaure both sensor outputs with respect to the same ground i.e. the DAS ground ?
e: I am using an NI Data Acquisition board (PCI-6023E) with LabView taking inputs from temperature sensors (+5v VCC and 5V Vo) and airflow sensors (+12V VCC and 5V Vo). Can I mesaure both sensor outputs with respect to the same ground i.e. the DAS ground ?This should be placed in the DAQ section. With your information, I would say yes if the power supplies share the same ground.
(1,474 Views)
