I am trying to move a file via ftp
I am trying to move a file from my local share drive on my computer to another server via ftp protocol. I can log into the server and get acknowledgments after entering my user name and password. The problem lies when trying to send my file. I am getting an error which states unexpected command. I am trying to use the "put" command. This works in a dos window but the ni visa is giving this error not the server itself I believe. It occurs with the last write/read statement. I am attaching my vi. Any help would be appreciated. Thanks
(3,686 Views)
VISA supports TCP/IP but it doesn't support FTP afaik. NI sells an Internet Toolkit with FTP functions or you could use System Exec to run the DOS command. That's what I do for tftp transfers.
Message Edited by Dennis Knutson on 07-21-2005 01:43 PM
(3,680 Views)
Thanks for your reply. Since I do not have the toolkit is there another way to move this file to the server in my labview program once I logged into the server? I also tried datasocket but since this is not being run on the server it too did not work. Thanks for your help!!
(3,668 Views)
As Dennis mentioned, you can use the System Exec to execute DOS commands...your standard DOS ftp commands will work from there (put, etc.)
(3,665 Views)
I have a program that was working fine on a windows 7, 32 bit machine using the system exec. vi to do an tftp file transfer.
The computer bit the dust and has been replaced by a windows 7, 64 bit machine and now the code won't run the system exec command properly.
Do I need to change some windows setting to get this work correctly.
I have tried running as admin and that has no effect.
(3,070 Views)
Since you "hijacked" a decades-old thread, did you follow the original suggestion to use LabVIEW's FTP functions (such as FTP Put File)?
(3,051 Views)
