I am trying to latch a boolean indicator when true. Once it reads true I want it to stay latched even if the input changes states.
Hi Justin,
I too need it in LV 7.1. Can you repost it ?
- Partha ( CLD until Oct 2021 🙂 )
Message 11 of 20
(2,620 Views)
Hi Justin 😧
Can you post the TestLatch.vi on this thread in Labview version 7.1. I do not have Labview 8.0
Respectfully,
Nirav
Message 12 of 20
(2,609 Views)
Hello Nirav,
I've saved this VI down to 7.1 and attached it to this email.
Justin D
Message 13 of 20
(2,596 Views)
Hi
I am new to labview. I was also advised to use stop button to stop the program instead of Abort button. Then, can I know the purpose of abort button in usual program execution?
Message 14 of 20
(1,996 Views)
(You probably should have started a new discussion instead of adding to a five year old thread about a slighly different problem)
The abort button has no purpose in "usual program execution" (whatever that means). It can be used during development and debugging to abort a runaway VI, for example.
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 15 of 20
(1,994 Views)
hello everyone,
i hope that i am posting under the right header.
I did a program for led using case structure and while loop. but the problem is that the led is blinking. i
dont want it to blink. i want the pin to stay high then when i press the boolean, it shall be off.
the led pin is on my breadboard.
can any1 help
 the first snapshot i use a simple case structure
can any2 help. i was thnking to use the latch button but where should i put the reset
Message 16 of 20
(1,783 Views)
Hi Zahkay,
why do you hijack several old threads for your own question? Why don't you stick with your own threads?
Please keep your problem in just one place!
using LV2020 on Win8.1+cRIO
Message 17 of 20
(1,779 Views)
hello sir. it is the same link right. when i write it.
and i recheck i though i didnt write it on the same thread
hence it came on 2 thread
am sorry for it.
how should i delete it
Message 18 of 20
(1,776 Views)
In a case like this, I would use an XControl.  This case is rather simple.
Message 20 of 20
(1,202 Views)
