12-15-2008 08:30 AM
The build keeps telling me that I have 3 sets of files the same name from NI report
The VI's are creating 3 times the files I require
It also tells me to select renaming files
Can any body tell me how you do that
Solved! Go to Solution.
12-15-2008 09:04 AM
12-15-2008 09:08 AM
This is a (current?) limitation of the executable structure. Since you use the report generation (or any auto-dispatching class) LabVIEW needs to distribute these files outside of the executable, not something to worry about, however you need to make sure these directories stay with the executable.
See here for a KB article
Ton
