I am trying to communicate with third party instrument via usb but I dont know how to do it even in Ni-max I am not able to see usb port symbol in Devices and Interface section.
hello,
I am tring to communicate my Powersupply which is not from Ni via USB cable ,but I am not able to see my connection or usb symbole in Ni-max .
first time I am using this will you please guide me,and is there any driver i need to download for that?here I put one attachment regarding to this.
Thanks in advance.
Message 1 of 60
(5,885 Views)
Does this have anything to do with the other messages you've posted, starting with this one: http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Troubling-communicating-with-hp34401A-using-R...
MAX isn't going to show you the USB ports. The OS does that. MAX will only show you recognized devices. If the OS doesn't have a driver for the USB device, then you won't see it in MAX.
Message 2 of 60
(5,874 Views)
thank you for replying .
Actully I didnt get any solution by using RS 232 cable so I am trying with USB .
I am able to see my device in control panal but as i cant See it in NI-max,there is no any symbol for usb in devices and interface.
Message 3 of 60
(5,862 Views)
If the device is NOT from NI, you will most of the times not se it in MAX.
That doesn't mean you can't use it in LabVIEW, MAX just only shows NI products.
Message 4 of 60
(5,858 Views)
ok but I dont know how to use because when I was dealing with RS 232 then I was able to see the com port but now with USB i dont know what to do becase we dont have to do serial configuration in this.so what kind of setting required for that?in attachment you can see the screen shot in that i am not able to see the usb connection.
Message 5 of 60
(5,854 Views)
Don't even think about using the VISA wizard at this point and the image makes no sense. You say you are trying USB but the image shows Ethernet. There is a huge difference. Do you really know what you are using?
Message 7 of 60
(5,830 Views)
ya I know that,
thats y i asked you that y it is so because i am not able to see that usb port here i can see that much only.
thats y i got confused.
and I can see my hameg connection in my control panel and also in device manager.
http://www.hameg.com/drivers.0.html?&no_cache=1
this is website for hameg driver in that product select  hmp4040 than hmp4000 list will open in that i have download third one in which plug and play is given.
or here i send my vi it might be helpful.
Message 8 of 60
(5,815 Views)
STOP. The link that you keep insisting you downloaded a driver from is an IVI driver - not LabVIEW. I've told you that over and over again. Download the LabVIEW driver above it and THROW AWAY the code you have now.
Message 9 of 60
(5,802 Views)
@AnkitRamani wrote:
ya I know that,
How hard can it be to download the LabVIEW driver ??????
http://www.hameg.com/drivers.0.html?&no_cache=1&tx_hmdownloads_pi1[mode]=download&tx_hmdownloads_pi1...
Message 10 of 60
(5,796 Views)
