I have designed a vi that runs in a for loop. It takes data from the BNC-2110 (using the AI One Scan vi), and then calls a vi to adjust the measurements to a temperature. After this it displays an output on a plot (per input channel). After this program runs for a while (not always the same amount of time), LabView will close and a Windows (2000), application error box will pop-up. The box will simply state that an error has occured and an error log is being recorded.
Here is a copy of the vi that I am using. It may take up to twenty minutes for the error to occur. I think that everything is in order (on the programming end). It is a short program and if anybody can find
the problem, I would be very happy.
Any help is appreciated, thanks.
Tyrone
