I am in need of 3-way switch
Karthikeyan90 has already explained what a picture ring is.  Plus you have plenty of documentation to lean on, I'm sure you can do the research and fill in the gaps.  Are you reading your own thread?
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 11 of 22
(3,294 Views)
One problem which i found in the 3-way switch which u shared .. supoose if i press on that switch it goes to up state, agin if press it comes to middle state and again if i press it comes to down state but my requirement is if on up side it should be up state , again if i press it should come to midlle state , now again if press on up , it should to up state not down state ... the same follows for down state also .....
i am unable to overcome this problem .. if i add or remove the states. during run if i press on upper part of picture ring it should go to up state |||ly for all the states it should follow ..
Message 12 of 22
(3,244 Views)
For ur need, it is better to create an Xcontrol ( a custom control).
I will create an Xcontrol with following functionalities and upload.
Present state   Pressed key.      Final state.
up                      up                     up
up                      middle              middle
up                      down                 down
middle                up                      up
middle                middle                middle
middle                down                  down
down                  up                      up
down                  middle                middle
down                  down                  down.
If you need any change, post it as table above.
Message 13 of 22
(3,236 Views)
This is what i  wanted exactly.
Thanks a lot . Really
Thanks & Regards
Mahadev
Message 14 of 22
(3,224 Views)
Here i have created a Xcontrol. download the attachment.
Thanks & Regards,
Karthikeyan
Message 15 of 22
(3,206 Views)
Thanks for the reply
Do we require Xcontrol library? and how to run the attached file. and how to use that 3-way in my application.
mahadev
Message 16 of 22
(3,206 Views)
I am not sure. I think that it is inbuilt feature of labview. I am using Labview 2010.
Right click in the Front panel and choose Select a Control and choose the 3-way switch.xctl.
Or simply drag and drop the 3-way switch.xctl in the front panel.
Message 17 of 22
(3,202 Views)
Thanks a lot its working fine .. can u make a 3-d image ..can u change the apperance and make little bit attractive.
thanks
mahadev
Message 18 of 22
(3,200 Views)
I have defined up, down and middle buttons as typedefs. So, open the up.ctl, down.ctl, and middle.ctl and edit the images.
Click the wrench icon (near Typedef) in tool bar below the menubar.
Right click on image and choose import from file. Similarly change the picture item in the right click menu and change all images accordingly.
One of the image is on image. another image is off image.
Message 19 of 22
(3,193 Views)
If you are interested, I have This Idea about a Tri-State switch.
Richard
Message 20 of 22
(3,187 Views)
