I/O other increases steadily in labview 8.2.1
The I/O other item in windows task manager increases steadily when a loop is running in labview 8.2.1.   Why?
I use labview 8.2.1 and windows xp sp2.But Labview 7.1 is not.
(2,954 Views)
Did you forget to put the Wait primitive inside the loop, with a small delay value?
- Partha ( CLD until Oct 2027 🙂 )
(2,948 Views)
Thanks.
I  read a PXI 6528 digital input status inside a while loop, delay is 50ms.
 But memory increases continuously, the PXI system run slowly after 48 hours.
what can I  do?
帖子被wcon在03-17-2008 09:12 AM时编辑过了
帖子被wcon在03-17-2008 09:14 AM时编辑过了
(2,933 Views)
It is a example.
(2,926 Views)
You keep creating a new channel in your program. You need either to create it once or to close the channel after you are done in the sub vi. I suggest you create a shift register or place the initialization of the channel outside the main loop and inputted into the subvi. Remember to close the channel when done.
(2,921 Views)
