08-18-2006 11:57 PM
08-22-2006 12:11 PM
Hi there are many ways for making a chronometer in LabVIEW you can use time stamp, tick count or even better the Elapsed time express VI. For using the multiple clocks it’s really easy in LabVIEW you just have to make 1 chronometer and make it into a sub-VI, using reentrants sub-VI.
Here is a simple example you just have to customize it for your application.
08-22-2006 12:45 PM
This sounds like a description of the "Goop Timer Toolkit"
See here
http://sine.ni.com/apps/utf8/niepd_web_display.display_epd4?p_guid=B45EACE3EDA756A4E034080020E74861
That eaxample (I believe) was originally developed by Jim Kring of JKI, see here
http://www.ni.com/devzone/lvzone/member_kring.htm
Ben
09-18-2006 11:35 AM
09-18-2006 11:53 AM
09-03-2010 08:09 PM
hola benjamin , con respecto al archivo adjunto utilizast el elapsed time para hacer un cronometro. Estuve haciendo algo similar expresando el tiempo con este formato 00:00:00,00. Mi pregunta es si al cronometro generado con labview lo puedo tambien visualizar tambien en un display a leds de 4digitos ,7 segmentos , externo (pcb)? que formato le darias al tiempo para poder mostrarlo en el diplay y que puerto usarias??,, Alguna sugerenciaaa?
09-05-2010 12:46 PM
Spanish to English translation (google): hello benjamin, with respect to attachment utilizast the time elapsed for a timer. I was doing something similar this time expressing 00:00:00,00 format. My question is whether the timer generated with Labview as well I can also see a display to 4DIGIT leds, 7 segment, external (pcb)? what format would you give the time to show it on the diplay and port you would use?,, Some sugerenciaaa?
You are referencing a 4 year old post with a new hardware twist. I would recommend you start a new thread with a more descriptive title, e.g. "connecting an external LED display" or similar. You can still link back to this thread here.
Of course I cannot see how you could ever show eight digits (00:00:00,00) on a four digit display, but maybe something got lost in the translation. 😉
