01-20-2009 03:39 PM
I was upgrading cRIO software from NI RIO 2.3.1 to NiRIO 3.0, and the html file (viewing vi panel from web) that created earlier in LV 8.5 crashed. I also trying to ftp to sub directory inside cRIO and view it this html file.
ftp://host ip/ni-rt/system/www/lvtest.html It also crash error "Fatal error occured during operaion, closing connection"
So, I am not sure why t did that all i did just upgrade the software version.
Taylor
Solved! Go to Solution.
01-21-2009 11:24 AM
Taylor,
Rebulding your application and re-creating your HTML file is recommended after a software upgrade. Follow the steps outlined here.
Let me know if you have any more problems.
01-21-2009 12:06 PM
Hi Rob,
Thank you yeah you are right. It need to re deploy or something. what I did since can't find the original project so I was told to redeploy the new project and create a new html file(different vi), and put the html into the www dir. Then both old html and new html file are working. I guess I have to do this every upgrade of the new version of labview or NI RIO.
I also have some question relate to html vi start. Do you know the way to stop the vi inside html file beside right click and control the front panel and stop the vi. This process I will loss the control of the vi and shutdown remotly. So, I have to reboot the controler again in order to start this vi form html file.
Secondly, do you have a way to check the space availabble inside cRIO. I can't check it form ftp.
Taylor
01-21-2009 01:45 PM
When you stop your Remote Front Panel, you have to reboot to get it back up again. That is just how the front panels work. You shoudl design it where it does not need to be stopped.
To see the available disk space, go in MAX and left click on your target. On the right pane, there will be a 'System Settings' tab which will show the total and availablme memory.
