before I get into my problem im going to give details of my program.
Now I am using the myDAQ assitant to retrieve volages from a thermistor. I am then converting this voltage to a tempreture then mapping this tempreture on a waveform chart over time.
I am also working out the minimum , maximum and mean tempreture that has been recorded over time. Now I need to write this data to a plain text data file logging the measrument history over the applications run time. I need to include the minimum, maximum and mean tempreture recorded at the end of this file. I am really struggling to do this (my first program I am writting with labview).
I am unsure on which tools I should use, if I was pointed in the right direction on which tools I would need, im sure id be able to figure it out.
I have attached my program as an attachment, any help would be greatly appreciated.
Kind Regards
Ahmed
