How to write a tab in a listbox
I work with Labview 8.5 and I try to write several sentences with tab (\t) in a listbox but it does not work.
The Tabs are represented like simple space (\s) ?!
See my example in attached file
Nono
(2,815 Views)
As far as I know you can't display tabs in listboxes. One thing you may want to do to consolidate your code is to use a look to generate your item names, using the Format Into String function to allow you to easily change the spacing in once place, rather than in each individual string:
Message Edited by smercurio_fc on 07-08-2008 09:29 AM
(2,766 Views)
Thanks a lot for your answer. In fact, what i tried to do was not possible...
(2,742 Views)
