How to write a program to read data through PXI?
Hi folks,
I want to develop a program to read external data acquired through PXI through LabVIEW. So far, I have managed to detect the PXI chassis (PXI-1033) and the RIO (PXI 7813R) through MAX. I have an SCB connector block, which I plan to feed in my signal.
Any idea how I should go about this?
Any help would be much appreciated.
Thanks, Anoop
(3,356 Views)
Advice: Read the LabVIEW tutorials/basics.
Seriously, a bit of time spent now understanding the fundamentals will pay off hugely in the future. Also have a look at the example programs that ship with LabVIEW (Help >> Find Examples)
Of course you can post back if you hit a specific problem and people will be more than happy to help, but it's best if you at least have a go at it first.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(3,353 Views)
Thanks for the reply.
I have decided to take a step back and actually look at the PXI-7813R for now.
As I understand, The PXI-7813R has a reconfigurable I/O and an FPGA module. Using this I/O module, I can feed in signals/data into the PXI.
1) Does the I/O module have to be programmed if I were to 'see' the data read/wrote in to the PXI?
Once the data is read/wrote in, I will have to feed them into the FPGA module.
2) So, do I have to program a specic FPGA module for this on labview, based on the data in?
Note: the data will be fed in through an external device, which will supply 6 different waveforms/signals.
Thanks, Anoop
(3,342 Views)
This would be a good document for you to follow:
http://www.ni.com/white-paper/3261/en
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,338 Views)
