How to write a function block?
Hi There,
Does anybody know how to write a function block with LabVIEW?  Something like those in Real-Time VIs>>Function Blocks>>.
Thank you very much in advance?
Message 1 of 9
(1,090 Views)
Highlighted
Hi qing,
seems you need to go through all those free LabVIEW beginner courses offered by NI.com!
Start here: www.learnni.com or here
CLAD expired, using LV2011SP1 + LV2017 (+LV2019 sometimes) on Win7+cRIO
Kudos are welcome Smiley Wink
Message 2 of 9
(1,086 Views)
Hi Gerd,
What is the course title?  Thank you.
Qing
Message 3 of 9
(1,079 Views)
Hi Qing,
use the second link and go through them all…
Message 4 of 9
(1,070 Views)
I could not find contents on 'Function Block'
Message 5 of 9
(1,054 Views)
Second link in message #2: first chapter on "Environment basics", paragraph on "subVIs"…
Message 6 of 9
(1,050 Views)
Accepted by qing_shan61
Assuming you are referring to these specifically...
http://www.ni.com/white-paper/7339/en/
...then the answer is that it is nearly impossible to make a new one. However, there is really nothing all that special about them. They are essentially normal subVIs (which you can learn about from the other links) that just happen to have certain terminals bound to shared variables. I personally wouldn't normally recommend that anyway. If you could clarify what specifically you are trying to make, it could be possible to give more targeted advice.
Message 8 of 9
(977 Views)
Hi SmithD,
Thank you.  You answered me.
Qing
Message 9 of 9
(936 Views)
