I want to write a string of format %f (for ex. 14.316523E-06...)to a spreadsheet file, the result I get is 0.000014. So the result is limited to 7- digits and this way I lose some important precision. I use the write to spreadsheet file vi with format %f and I changed the representation to EXT but without any result. Anybody?????
f_d wrote: > I want to write a string of format %f (for ex. 14.316523E-06...)to a > spreadsheet file, the result I get is 0.000014. So the result is > limited to 7- digits and this way I lose some important precision. I > use the write to spreadsheet file vi with format %f and I changed the > representation to EXT but without any result. > Anybody?????
You should be using %.9e to get scientific notation. (eg. 1.23456789e+26)
Have a look in the help under Format Specifiers Syntax Elements
-- Remove "spamkill." when replying to this message
> Have a look in the help under Format Specifiers Syntax Elements ... or make an 'format into string' function, rigth click on it and togle 'edit format string' ... I think that is the easies way to work with format strings
