How to wirte the cursor more near the XY position
I have the following program attached: "Cursor_name"".
I need the cursor name to appear more near the XY position (point).
How can I do this?
AS
(3,063 Views)
Simply drag the label with your mouse. When you save, the position relative
to the point will be stored as well.
Wiebe.
(3,052 Views)
Thanks for writing! 🙂
I need the cursor to name to appear near the XY position by itself. See picture attached.
Thanks & Kind regards,
AS
(3,048 Views)
So click on each label, and drag them with your mouse to the desired
position!
Wiebe.
(3,041 Views)
Thanks again!
For some reason, I can't make it work. I can't move the label.
Could you explain how to do it?
AS
(3,029 Views)
Take as starting point your original VI
http://forums.ni.com/attachments/ni/170/277379/1/Cursor_name.vi . I open it
in LV 7.1 (and I think you use 7.1 too).
The front panel is open. I'm still in edit mode, this might not work during
exection. I can simply click on a label, and keep the mouse down. Then I can
(with mouse down) move the cursor.
Wiebe.
(3,019 Views)
Hi Wiebe,
Thanks for the help!
It is working now. 🙂
Kind regards,
AS
(2,997 Views)
