How to view different sine waves in an array and make an fft of these and display it in one graph?
How can i cannect the output of my mathscript in the Spectral Measurements VI SIgnal Input. I'm having a problem since the output of the mathscript file "D" is DBL 2D. I dont know how to convert this data type in order to be connected to the signal input of the Spectral Measurements VI. I also want that the waveform graph connected to output of the Spectral Measurements VI, will display the FFT of the three sine waves in one graph.
Message 1 of 8
(4,438 Views)
Don’t Create Multiple threads.
http://forums.ni.com/t5/LabVIEW/How-to-view-different-sine-waves-in-an-array-and-make-an-fft-of/td-p...
You should build waveform for every signal.
Munna
Message 2 of 8
(4,427 Views)
What do you call that orange table? Where is it located in the functions pallete?
Message 3 of 8
(4,415 Views)
i.e. your Output Data coming from Math script.
example I created 2-d Array Constant.
From, Array Pallet --- > Array Constant --- > Drag n Drop DBL in that array (from Numeric Pallet)
Munna
Message 4 of 8
(4,405 Views)
How do i connect the output of my mathscript file to the 2d array? Sorry Im still new in LabVIEW
Message 5 of 8
(4,384 Views)
Accepted by jamison.suade
Don't Connect. Just pass it to Forloop.
Munna
Message 6 of 8
(4,373 Views)
Ok thanks i get it now. thank you 🙂
Message 7 of 8
(4,371 Views)
While building waveform just think about your 2D array. Because For loop reads your Data by rows. If you want to read it by column then use “Transpose 2D Array.vi” (before passing into For Loop). And also think about other parameters in your waveform data (i.e. dt , t0).
If your problem got solved, make it as “Accept Solution”
Munna
Message 8 of 8
(4,363 Views)
