Hello Zamzam,
you get the values for the x-range from your chart. The values are copied to the two graphs. It's all correct up to here...
Now you want to change the x-range. Where do you want to change it?
At the moment you have to change it at the chart x-axis to promote it
to the graphs. But: the chart is constantly getting new values and so
it changes it's x-axis (counting forward, changing displayed range and
so on).
So my advice: Make two controls: x-range min and max. Wire those
controls to the property nodes to set the x-axis of the two graphs!
(Maybe use some logic on your own to prevent 'wrong' settings by the
user.)
